ID de artículo : 00107252 / Última modificación : 18/02/2015
Preguntas más frecuentes relacionadas con la conectividad USB para mi cine en casa
Can I use a USB memory device with this Home Cinema?
Yes, you can. If you wish to use a USB memory device as local storage for the BD-LIVE function, please make sure it has a capacity of at least 1GB.
The current disc playback stops when a USB device is pulled out.
This is a normal operation of the BD player. Do not connect or disconnect USB devices from the player during playback in order to prevent playback from being disrupted.
