ID de artículo : 00129346 / Última modificación : 10/09/2018
¿Qué formatos de audio comprimidos son compatibles para la grabación directa de CD y su reproducción?
The corresponding codec or audio file extension types supported for CD direct recording and playback are as follows:
  1. MP3:
    • Sampling frequency: 8kHz, 11.025kHz, 12kHz, 16kHz, 22.05kHz, 24kHz, 32kHz, 44.1kHz, 48kHz
    • Bit rate: 8kbps to 320kbps (VBR compatible)
  2. WMA:
    • Compliant with Windows Media Audio 9 Standard
    • Sampling frequency: 22.05kHz, 32kHz, 44.1kHz, 48kHz
    • Bit rate: 32kbps to 192kbps
  3. AAC:
    • Profile: MPEG4-AAC-LC (Low Complexity)
    • 44.1kHz, 48kHz
    • Bit rate: Max. 320kbps (VBR compatible)
    • Number of Channels: 1, 2
NOTE: Digital Rights Management (DRM) files cannot be played back.
