No se puede cargar un dispositivos móvil utilizando el sistema de componentes Mini Hi-Fi.
Check the following if the mobile device cannot be charged using the Mini Hi-Fi component system:
- Make sure the device is securely connected to the Mini Hi-Fi component system and that the system is turned on and working properly.
NOTE: When the Mini Hi-Fi system enters standby mode, the mobile device may stop charging. Disable the Automatic Standby function to prevent the Mini Hi-Fi component system from going into standby mode automatically.
- Press OPTIONS
- Select AUTO STBY
- Select OFF
- Set the Mini Hi-Fi system to USB function.
NOTE: The mobile device might not be compatible with the Mini Hi-Fi component system. While most mobile devices should charge, Sony cannot guarantee that the system will be able to charge any device.
